W7 Installation Problem
12 Dec 2003
I'm trying to install W7 x64 and I get stuck after selecting the install language.
It says "a required CD/DVD drive device driver is missing. If you have a driver floppy disk, cd, dvd, usb flash drive, please insert it now", I assume it means the RAID drivers since I've just setup RAID on my 2 new drives.
I put the JMicron JMB36x Controller drivers (my RAID controller) on a USB stick and when prompted browsed to the /driver/amd64 folder with the driver in it (jraid_i.inf) then clicked next. After a while the installer says "no new devices could be found. Make sure the driver files are correct and located on the driver installation media". Or if I load the drivers from the repair menu I get the error "windows could not collect information for [OSImage] since the specified image file [install.win] does not exist."
I tried disabling my RAID array and I STILL have this problem... what drivers does it want?
I also get the same driver message if I try to install vista 32, but using the 32 bit RAID driver works and installs!
