I really need to fresh install my windows, I've used the OEM W7 home64bit on this machine, i was wondering if i could use the key again on the same machine, but does it matter that i've activated it?
Also is there a way to change my refresh rate, for some reason it's set high, i have to boot in safemode with networking? anyway to change this as i can access Nvidia control panel :L
right-click desktop and choose screen resolution, then click advanced settings and go to the monitor tab, hopefully you can see the refresh rate there.
