W7 problems - advice please
17 Sep 2006
I recently upgraded my system to W7 Pro. H/W is an Asus P5Q Pro, 4Gb and an Intel quad core which has all been running XP fine for about a year. Bought a new 500G drive to put W7 on.
Installation went fine and it found drivers for everything except the NIC which i got from the Asus site.
It ran mostly ok for a few weeks but the occasional 'stop dead' - no BSOD, no nothing. Then it started to hang for about 20 secs at a time.
Ran HDTune and it found some damaged block but I'm not sure if they are really damaged or if W7 has just decided to mark them as such.
Memtest says all memory OK.
Updated to mobo drivers from Asus site and things got much worse. e.g. CD drives disappeared until I rolled back the Marvel drivers. Now VERY flaky.
I'm resigned to doing a complete re-install and I'll get a new HD and new graphics card (Currently FireGL V3350 which has no speficic W7 drivers).
Questions?
Stick with the P5Q?? (Worked ok with XP)
If so, stick with W7 installed drivers or go with Asus ones? (Caused grief this time).
I don't mind the rebuild but I'd be happier if I knew what was causing the problems :(
Any thoughts
Thanks
Steve
