- 18 May 2010
I'm looking at a new system drive so I'm wondering if its worth getting W8 upgrading from W7 64 for what is primarily a gaming PC?
Thanks
Thanks
Anyone would be crazy not to pay £24 for w8 proI upgraded to make use of the £24 offer which expires at the end of Jan I think.
Just seen the £24.99 offer for the Windows 8 upgrade which im probably going to get just because its cheap.
Just a couple of questions though:
How do I go about reinstalling Windows 8 in the future when I just own the upgrade verion?
Do you get a serial key? If so can you just download the retail version of Windows 8 Pro and just use the serial I get with my upgrade version?
sorry for the partial thread hi-jack.
The Upgrade Assistant downloads the media that you can save as an ISO.
Just clean install using that as bootable media (Either burnt or from USB stick) use your key then activate. If you have trouble activating then you can change a registry key and run a single command prompt/reboot and voila - activated.
TBH though the more I read about it the more I'm being persauded to keep my £25 and stick with Windows 7
