W8 tablets..
7 Jun 2003
Gloucestershire
Simple question this one really...
Are there any Windows 8 tablets, as in full windows 8 not the RT version, for less than £450? regardless of what their spec is, whether they offer a keyboard etc, i just need the tablet running the full windows 8 experience.
Any models anyone can recommend? does such a thing currently even exist? :)
ASUS ME400C
Would i be right in thinking that wiping the OS off one of those would be easy enough to do if say i wanted to put windows 8 pro (even if it does have to be the 32bit variant) on to it?
EDIT: Nevermind, the first link i looked at said windows 8 home, but every other one is showing windows 8 pro anyway. thanks
I think all the UK models have Core on them, but yes you should be able to install what you want. Be careful I'm not sure if it support legacy boot so you may have to use a 64 bit W8.
