W800i Problem
21 Dec 2004
London
Trying to transfer tunes from the pc to the phone via drag and drop, but it says 'the disk in the destination drive is full', even though the phone has no MP3s on it. It's never happened before, anyone have any suggestions as to what the problem might be?
make sure its not sending it to the phone memory and that its deffo to the memcard, or you could just copy all the files manualy to the folder job done :)
What software are you using? Also, again make sure it's the memory card you're coping to and not the phone's memory.
No see the problem had nothing to do with using a card reader. After I had deleted all the MP3s from the phone to relpace them with new ones, it wasn't allowing me to transfer any tunes because it said the disk drive was full. I checked the memory stick status, and it only had 3mb of space free, even though there were no MP3s on it. I tried using my card reader but same problem.
So I actually formatted my memory card, and it solved the problem.
BoomAM said:
It is far easyier, quicker and problem free to just use a memory card reader. :)
You'd think! I bought a card reader for this very reason but now it doesn't find the card when I put it in, think the phone may have currupted the card again!
Turn the phone off with the card out. Turn it back on with out card. Once it's up again try putting the card back in. And check then. What size card by the way?
Its a 512Mb with all W800i's.
Do you switch off the phone when you remove the card? And then keep it switched off until the card goes back in?
I found that that helps.
