I bought a Sony W829 TV and BDV-E3100 5.1 Home Cinema System recently.
Initially it all seemed to be working ok. I got proper 5.1 sound for Blu-Rays and through Netflix app on TV using ARC. I couldn't get true 5.1 sound from my Sat Box or my HTPC (both connected to TV via HDMI) but I accepted that this was a limitation of ARC. However 2.1 sound would still use the rear speakers but would just output the same sound as the stereo speakers.
Then recently I noticed that the sound just wasn't right and the rear speakers no longer seemed to be used for TV/HTPC so started to play around with the setting to get it working. I then put the home cinema system into Dolby Sound mode which will replicate the stereo sound through the rear speakers as before for TV use.
I then noticed that 5.1 wasn't working on Netflix app any more so changed it back and now I don't seem to be able to get my 5.1 sound working again for Netflix. My choices are just stereo sound or stereo sound but using rear speakers. I can't get proper 5.1 for anything. I haven't tried a BD disk yet to confirm if this works.
I have checked the connection and loaded a 5.1 test through TV youtube app to check the speakers. This confirms that 5.1 sound is not working - although I don't know if this worked for Youtube app before
I would imagine it works for Netflix app then it should work for Youtube app as well.
So my question is how does Arc work? Should it be able to do 5.1 sound for all devices plugged into my TV via HDMI?
Does anyone have any idea of settings for the TV or Home Cinema system which could affect this? My gut feeling is that it's something set on the TV not the HCS.
If I used an optical connection instead would this pass 5.1 sound for this TV?
