If you are meaning with some bluetooth stereo headphones then no because it lacks the A2DP profile required. Like the K750i/W800i the hardware appears to support it (being BT 2.0) but the profile itself it is not implmented in the firmware. The first SE handset to fully support A2DP will be the M600i/W950i and the P990i.$ilent\\'@rrior said:Does anyone know if you can use a bluetooth headset to listen to the 'Walkman' on it??
Thanks in advance guys.
This headset will only work with phones supporting A2DP like the upcoming SE P990/M600/W950.matt100 said:
