Wall mount for U2311H?
Caporegime
4 Jun 2009
Having a look around for a wall mount for my dell u2311H as I want to save some desk space and have the monitor moved further back a bit (desk is tiny so can't move the stand/base back any further :p :o).
However, I am shocked at the pricing for the majority of these mounts etc. :eek: I don't want to spend any more than £15 on one and I can only really see a couple that come across as being good/popular.
I am currently looking at this one (can get it for £10.95) as it seems pretty good from the user reviews on a certain site. It folds flat to 5cm.
- Brateck Cantilever TV / Monitor Wall Mount Arm / Swivel & Tilt For Up To 24 inch Screens
So, is there anything else better out there for less than £15 that folds completely flat to 5cm or preferably less?
Thanks in advance :)
The bracket you mention in the OP looks like a good one and should work fine with the U2311H.
The main thing to look out for when buying a mount for the U2311H is that you get a mount that isn't too much bigger than 100x100mm as the VESA screws are recessed. Though you could use spacers to get round this.
have you looked on http://www.bracketfinder.co.uk they may well have something
Yup, have come across those sites as well but I can't really see anything listed there that offers much more than the one I mentioned for a similar price.
Guess I will just go ahead and get that one then, was hoping that there would be something similar to it but be able to fold even flatter whilst retaining the swivel features etc.
