Hi Chaps,
I was going to renew the case for my PC in the next few weeks and I was looking at a thermaltake P5, but now honestly I am thinking of just using MDF and Acrylic and making my own.
I wondered if there are any key points I should take into consideration regarding placement of components?
I am just drawing up a sketch now, and I noticed a thread on another forum where someone suggested NOT putting the radiator above the motherboard as heat from the board rises and goes into the fan on the rad above it. My initial idea was to put the motherboard to the side and have the cooler above it, GPU below it, but I guess that may have to change.
Anything else to consider?
Cheers!
Cheers!
