Wall-Mount Suggestions D:
13 Feb 2012
Midlands
Once again I have an issue, so I come to the only place I know where people will help me without judging me...at least not publicly!.. I hope
I've never wall-mounted any screen, so if someone could recommend / confirm the below, would be much appreciated :D
Decided to purchase the Samsung UE32H6200 after reading around and looking at reviews this appears to use 200x200 Vesa? for mounting (Cannot find a direct source for this though)
I'll be looking to mount this at 90degrees to the wall its on, as its going at the base of a wall-side bed.
It's not going to be linked to a tv-box or anything, so the only cable that will be running is for the power, maybe a Raspberry Pi in a couple months
Can anyone link me / recommend a wall-mount that will do this, without sagging, break, or cause me any issues :confused:
Sorry, my first post may not have been, when i say 90degree to the wall i mean:
Just grabbed the image from Google - doesn't have to be exactly as shown
The mount you linked doesn't appear to do this?
There isn't really a budget for it, 'cause this isn't a market I've ever looked at, so it costs what it costs to get the job done (:
Any of those on that website that you'd specifically recommend?
You need one with enough reach to hold the TV out from the wall though, which might be pushing it with a 32".
I have always tended to buy Vogel's brackets - from the Pro range for stuff at work, and the normal range for home use. They aren't cheap but they never seem to wear out like lots of cheap swivel brackets I've had the misfortune of dealing with. And they are supplied with good quality fixings.
