Taking a hedge down in the next couple of weeks to free up some space for new sheds but need to replace the hedge with a 1m high fence on top of a 6" block wall.
Original plan was to use these
But the dimensions put the top plate bolt holes too close to the edge.
Second option is
Drill centre of the wall and resin fix these in.
Anybody done this recently or used the above options for feedback?
Backup plan is to fix studs up the whole height of the wall but hoping to avoid this.
Birkdale Fencemate Swift Clamp Wall Mount Post Support
This support is specifically designed for securing 3 Inch posts to the top of concrete or brick walls. Suitable for trellis or fencing up to 1.2m high. Available in Galvanised or Epoxy Brown finish.
www.e-hardware.co.uk
Second option is
Heavy Duty Galvanised Concrete In U Shape Pergola Fence Post Support 60mm Depth
Unlock unbeatable savings! Click now to discover exclusive deals from TG Supplies - A National Distributor of Building Plastics, Hardware, Pergolas, Carports, and more!
tgsupplies.co.uk
