Wall Mounting LCD
16 Mar 2004
Oxford
I'm looking to wall mount my Samsung LE32R41BX, However most of the brackets available are 200x100mm, would this type of bracket be ok to use on the TV or should I pay the extra and go for 200x200mm?
Am using one these wallmounts to hold my pioneer 43" plasma on my wall..
AV4-BT8422 - Universal lcd tv plasma wall mount bracket Hook on Universal wall mount for up to 61" Screens
I don't know if this is any help to you or not..
I put the model number and spec for the LCD one below..
AV4-BT8421 - Universal hook on lcd wall mount bracket for up to 40" LCD Screens
* Ideal for Samsung, LG, Phillips etc 32-inch LCD
* Universal fixed wall mount for LCD and Plasma screens between the sizes of 22" and 40"
* Maximum Weight 35Kgs
* Quick and easy ' Hook - on ' installation
* Slim-line design allows the screen to mount just 30mm from the wall
* Wall bracket dimensions 500mm x 100mm
* Maximum distance between mounting holes Vertical 250mm , Horizontal 475mm ( For wider range see BT8422 )
* Compatible with VESA mounting patterns
* Includes locking bar for secure installation
* Simple assembly - all fixings included
Picture of the LCD one.
i would imamine 200x200 would be more secure.
