Wall mounting TV, 49" Position reusing for 55"?
19 Dec 2003
UK
Hey folks,
Long story short, we had a 49" TV which has been playing up for some time, and has finally reached the point of no return, ie, broken and is being replaced with a 55"
We had the 49" wall mounted on a tilt/swivel bracket, it was a Sony, and the new one is also a Sony, the only difference I could see was, the existing one specifies vesa mount of 200x300 and the 55" says 300x300
Assuming the stand is compatible, will it need moving (the fixing to the wall part itself) ? Or can I simply swap it over and keep in same place?
If the backplate fits on your new TV should be able to keep it in the same place.
Does your current bracket support the weight / size of a 55" ?
