Wall plug removal
21 Apr 2011
Any top tips for removing wall plugs from plasterboard without taking half the plaster around the exit hole with you?
I have filler and sandpaper but trying to save myself too much chew on.
I went with the screwdriver down the middle method and it isn't proving to be working well.
21 Apr 2011
Doi didn't think of leaving the screw in a bit. Awesome thanks, will give that a go.
12 Dec 2004
the south
find a drill bit that's just slightly larger than the hole in the raw plug. drill right into the center of the plug, this normally spins them free.
4 Aug 2016
I just usually grab them with long nose pliers and wiggle them out gently..
Top
