I think it should be illegal to mount a lcd/led/plasma tv any other way
Personally dont see the benefit in most situations, as by the time you've found a shelf for the centre speaker, av receiver, bluray player, htpc, sky/virgin box/xbox etc, you might as well just have the TV sat on top of it?
Whatever you do, don't make the same mistake thousands of others seem to. Mounting it stood up! Middle of the screen at eye level when your SAT DOWN! It looks bloody stupid above fireplaces etc. and you just wreck your neck. You wouldn't buy a 1.5m high tv stand would you, so why are you mounting it that high?
I'm looking to wallmount a 50" Plasma.
Firstly, where's a good place to get a wallmount from? I'd be after one for turn and swivel.
Will this affect Plasma buzz? I imagine with it being affixed to a solid surface could amplify the problem.
Depends how ugly the stand is
I guess it's about where the TV's going to be mounted as well though, if it's only just higher than where it would normally stand then i'd agree with you Tom. If it's going to be a fair distance further up the wall though then things are different!
I have my TV in a corner and I've yet to see a sensible way of wall mounting it so it sits at the same angle it does on a TV stand a lush wall mount in a corner really is not an option.
I know you going to say I shouldn't have a TV in a corner I need to be square on to it etc but the only way to do this would be to re-arrange the whole living room around the TV in the bay window which is for to chav for me to consider.
Wall mounts work great in some situations especially modern houses and flats with boxy shapped rooms and no features they don't however work very well in a traditional victorian style house with all it's origional features intact.
I actually wouldnt rent/buy a house if i couldnt have the TV central with speakers either side.
