Yes, thats right. I generally go for 3-4 walls, with 5 layers top and bottom. Give decent prints with good strength. Also, it can depend on the material (a bit of trial and error needed depending on your printer)Ahh is see. So if i change wall thickness to 1.2mm does that mean it will automatically use 3 walls of 0.4mm size?
