Want a 32" 1440p 240hz+ monitor...
22 Nov 2010
Kettering
But I don't know what to go for.
I currently have a LG 27GL750-B but want a 32" and to also have 240hz plus.
I mainly play Apex legends, so it's for this game mainly, I've seen the Nvidia reflex monitor's, would it be worth the extra? I can't say I've noticed any delay having reflex on and FPS uncapped.
So, what 1440p 240hz+ panels are worth a look? I don't mind a curve as long as it's not a aggressive one, also 32"+ only
Also using a 3070ti with a 5800x
Budget about £600-650
Seems like a good fit for your requirements and a decent price for that model. (also the C-clamp is a standout feature for me at that size!)
@Baddass or @EsaT may be able to provide you with some more detailed advice!
Thank you.
I've also seen the Acer Predator XB323UGX for £599.99
I don't mind spending the extra if it has a better panel, colours etc
I'm afraid I don't know a huge amount about panel tech, just that I've always liked the IPS monitors I've had.
There aren't many IPS options at 240+Hz about so they may even be the same panel...VA screens seem a lot more common at that refresh rate, however from reviews I've read they don't always handle motion well, despite the Hz.
Are you firm on the 240Hz requirement? - There are loads of options at 144+ :)
Basically (AFAIK):
IPS= good colours, bad blacks/contrast and commonly have backlight bleed, so dark scenes can look washed out
VA= higher contrast/deeper blacks, but can be prone to ghosting and not as good viewing angles
(TN= best speed, horrible angles....I'm sure they are better now than they used to be but I still wouldn't go there personally)
Not that many options for those requirements.
XV322UX would be another Acer.
All three are propably with same panel, because can't see many panels with those specs existing.
I'm leaning towards the XB323UGX at £599.99
Just want to make sure I've not missing anything before ordering
I used to have a Acer Predator laptop, CS was ok for me to be fair, I want the monitor by Thursday really, I don't think ocuk could get me the aorus by then
I ordered the gigabyte FI32Q-X in the end, £80 cheaper and with steam voucher, seemed like a no brainer.
Would be nice to know when to expect it tho as it's currently on order
