Want an Oculus but says not ports are not compatible. Etron Controller?
14 Nov 2006
Shoeburyness,England
Hi,
I did the Oculus compatibility check and says that my USB ports are not compatible, says it doesn't meet the USB 3.0 requirement..my motherboard is a GA-Z68AP-D3 and it has USB 3.0 ports..
What do I do now? Is the compatibility checker wrong??
Some boards don't have the bandwidth to max out all the usb 3.0 slots so the oculus software grumbles or you get glitching. As said, a usb pci-e card will help. I needed one for the extra sensors.
Check what USB 3.0 controllers you have, my Z77 Asrock Extreme 6 mobo has 2 different controllers, Etron and Intel.
When i ran the test it was detecting the controller it doesn't like and said it wouldnt work but after some research i found i had to use specific ports that are controlled by the Intel controller (I think its the Intel ones anyway).
What mobo do you have?
A look online suggests the Etron is only for 2 of them and the rest are using the chipset sp probably fine. My old CV1 works on an old USB2 only system fine.
I have a Gigabyte GA-Z77-ds3h with 2 USB 3 ports and my Rift CV1 worked mostly fine. Only issues I had were with sound breaking up after a few minutes of play. I bought an Inateck KT5001 PCIe card and it solved all the issues.
