- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys!
Adding hotswap bays to your Lian Li case has never been so easy. Just a couple of screws and you're all set! With one, two or three bay options!
Stock lands next week.
Lian Li BP1SATA 1x-Hot-Swap-Backplate @ £6.95 inc VAT
The Lian Li BP1SATA Single Bay to 1 x HDD SATA Hotswap Backplane doesn’t have a RAID or SATA chip on the PCB. It requires a motherboard which has RAID onboard and SATA capabilities to enable the hot swap and RAID features. This is designed for most Lian Li cases.
- 1 Bay to HDD SATA Hotswap Backplane.
- The SATA back panel doesn’t have a RAID or SATA chip on the PCB. It requires a motherboard which has RAID onboard and SATA capabilities to enable the hot swap and RAID features.
- Compatible with LIAN LI cases: PC-Q16 / PC-V355 / PC-V650 / PC-B12 / PC-7H / PC-D8000 / PC-A75 / PC-A76
Only £6.95 inc VAT.
ORDER NOW
Lian Li BP2SATA 2x-Hot-Swap-Backplate @ £10.99 inc VAT
The Lian Li BP1SATA Double Bay to 2 x HDD SATA Hotswap Backplane doesn’t have a RAID or SATA chip on the PCB. It requires a motherboard which has RAID onboard and SATA capabilities to enable the hot swap and RAID features. This is designed for most Lian Li cases.
- 2 Bay to HDD SATA Hotswap Backplane.
Only £10.99 inc VAT.
ORDER NOW
Lian Li BP3SATA 3x-Hot-Swap-Backplate @ £14.99 inc VAT
The Lian Li BP1SATA Triple Bay to 3 x HDD SATA Hotswap Backplane doesn’t have a RAID or SATA chip on the PCB. It requires a motherboard which has RAID onboard and SATA capabilities to enable the hot swap and RAID features. This is designed for most Lian Li cases.
- 3 Bay to HDD SATA Hotswap Backplane.
Only £14.99 inc VAT.
ORDER NOW
Only £6.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
