Want some loud earbuds/earphones?
12 Jun 2005
As title really.
I am finding that my N85 isn't loud enough so I was hoping someone could recommend me some loud earbuds/earphones.
I know there is a limit without any actual amplification going on but I was hoping to get some loud-ish ones.
Thanks.
EDIT: forgot to say that my limit is around £15
IEMs will help if you dont want to go external amps. I have a pair of Westone UM2 that hardly need any juice to make loud... but thats out of your price range and would be an overkill on a phone.
Try Sony EX85 and try my EX90 mod on headfi.org. Once the vents are sealed they are very sensitive and loud (lots of bass too).
I have some Shure SE110s, which you might just be able to pick up for £15 if you look hard and get lucky. Full volume when hooked up to my N95 would be deafening (and I'm a Fabric member, so I'm not exactly noise-averse)
Not looking for something so expensive. The sound output on the N85 probably wouldn't justify it.
How are the Goldring GX200's cause they are quite cheap now.
