just set the memory multplyer to 2, and up the CPU Host controll by 25 each time.
keep everything else on auto, and run a blend test for 20mins inbetween each step up.
having said this you can probly up the CPU host controll to 333mhz straight away.
Hi aph
I have just upped my FSB in 5 steps at a time from 3.16 GHZ I'am now at 3.8 GHZ, I did this in the bios... I also turned off speedstep to get a true reading at what the cpu numbers were..
Hi, just tried the setting as advised above. As yantorsen mentioned, I jumped straight to 333MHz. Unfortunately, the system didn't boot for a few secs, and then when it did - according to CPU-Z everything is as before. So I presume the BIOS didn't like the settings and reverted back to it's default. How annoying.
How do I turn off speedstep?
go into your bios mine is called Intel Speedstep either Enable or Disable mines disabled
Yeah, I thought you might say something like that. Currently the BIOS on my board doesn't present that option. Whether it's just not there, or there under another name I'm unsure.
PCI Express Frequency
Could be left on auto
or manually set to 101
some folks advise manually setting 101
333 Mhz might be a bit much to start with.
11 multiplier on that CPU.
He would need quite a bump in the vcore to pull that off.
CPU Host Clock Control
toggle to manual
Set to 266mhz initially
That will give you a 33% overclock for starters
CIA 2
Leave disabled
Robust Graphics Booster
Leave on auto
High Speed DRAM DLL Setting
Leave on option1
