Want to upgrade my graphics card ???
10 Jul 2006
Hampshire UK
Hi,
Go a new pc about 6 months ago with P4 3.4GHZ, 2GB Ram etc. It came with a Radeon X550 but I would like something better, but theres hundreds to choose from. Any suggestions on a good card that will make a noticable difference over my X550. I'm not a game player but use my pc for my simulator which is very graphics card hungry. The card they recommend that is at the top of their list is the R 9800 XT ?
I require a PCi Express type, any suggestions please ? I don't want to spend £100+ on a card and not notice any differance. I would say £200 is my limit, maybe could go a little higher ?
Simon.
For around £160 you can have the x1800xt 256 which is an even bigger performance difference! The two reocmmended thus far though are going to show you massive increases on what you previously had!
Thanks,
There seems to be a few cards in the 1800xt range is there any in partcular i should look for ? also is it worth paying extra for 512mb.
Simon.
http://tomshardware.co.uk/2006/07/10/can_your_rig_run_oblivion_uk/page11.html
from the looks of these:
i would say that 512mb would be the better option. :rolleyes:
I will stick with 256mb then :D
I've narrowed it down to these now then,
Connect3D ATI Radeon X1800 XT 256MB
Sapphire ATI Radeon X1800 XT 256MB
Whats the difference in the two, apart from £10 :p
HIS Excalibur ATI Radeon X1800 GTO ICEQ3 SILENT TURBO 256MB
PowerColor ATI Radeon X1800 GTO 256MB
Again whats the differnece in these two ? and also what the difference between the XT & GTO cards
Thanks
Simon.
With the Sapphire card you get to choose i think 2 full retail games from 4 - i think the ones are Tony Hawk's Underground 2, Brother In Arms: Road to Hill 30, Richard Burns Rally and Prince of Persia: Warrior Within.
If you want one of those games for a tenner it might be the go. Otherwise get the cheaper card.
Thanks
Simon.
These cards have different coolers. The HIS one is silent & cools a bit better to i believe. The HIS card is also overclocked a little faster too.
The X1800XT is the card to get. Not much more cost but the perfromance is 50-75% better. The X1800XT are the best bang per buck imo.
Caution though! Make sure power supply (PSU) is up to taking a X1800 XT :) Ideally should be...
  • At least 380w's;
  • & 22A or above on the +12v RAIL (if split, add up the numbers).
This info should be printed on the side of the PSU :cool:
