- 10 Feb 2010
Hi all!
Thought there may be a dedicated trading area, couldn't see one so sorry if this is in the wrong place.
Basically I've got an old Intel D875PBZ based Alienware rig (yes, it's rather old hat now
)) and I'm now using it as a bedroom PC. However, it's got a stock Intel CPU cooler, and it's far too noisy.
I'm looking for something quieter, ideally fitting into the existing stock bracket on the motherboard, but if I need to remove the motherboard and fit a bracket for a specific heatsink, I guess that's not too bad
Can't see anything decent in stock on any sites now, and on eBay I can only see cheap models which I doubt will be quiet enough (many state they are only good up to 3.0GHz, which suggests to me that if I did use them with my 3.2GHz, the fan would be on high all the time).
New or used, doesn't matter
Cheers!
Cheers!
