I am looking to build a mini Thin ITX Build not sure about some things. Not to sure if correct forum to post here or Small Form Factor, because it's an ESXI Question also.
Intel BOXDQ77KB
Unsure Which CPU ----Intel Core i5 3470T or Intel Intel Core i5 3570T Or High End Xeon E3-1265L Or Intel Core i7-3770T Which I think is roughly the same.(Probably overkill)?
Like the Vpro instruction intel have on some of these chips.
Corsair Vengeance 16GB (2 x 8GB) Memory Kit PC3-12800 1600MHz
Or could probably go with the value range.
Corsair Value Select DDR3 SO-DIMM PC3-12800 (1600)
Intel 60GB 525 Series SSD Msata
I looked at Plextor M5M, but I have had Intels since release never let me down.
Akasa Euler Passive AK-ITX-05BKAL Mini-ITX for Intel DQ77KB Ivy Bridge
I Have a WD Scorpio Black 500GB might use in this for extra storage.
The Box will be running a PFsense-Untangle Bridge a Windows 2008 or 2012 server and perhaps 1 Linux distro.
With all the Virtulization options and specification included on the board and chiips will USB passthrough work as though not in a virtual machine i.e direct I/O? I would like to run some HD TV tuners from a Windows 2008 VM
Anyone else got his setup? Can 2 drives be fitted in this case the Msata and a 2.5" Western Digital Scorpio? It looks as though it can following this article.
http://www.silentpcreview.com/article1321-page1.html
Intel BOXDQ77KB
