Warcraft - cosmosUI
7 Mar 2005
Wolverhampton
Any one use this UI on wow? Ive just renwed after 1yr and things seem different.
The things i want are
# All my 5 bags to be joined as one (cant find it on cosmos anymore)
# Messages telling me what quests my grp has and how many quest items they have got, and when they have all the quest items.
# When i joined a battleground i had this annoying little map in the middle of my screen and i dont know how to remove it? (Not the big M map)
# There are chat buttons above my left chat box like little colourfull eggs, I dont want them there!
Anyone got any tips ? Or is there a better add on like cosmos which i can simply download to make my wow experience much easier :)
Cheers (btw im on bloodhoof)
Same as you recently got it after about 6 months of not using it.
You can select/deselect them using the addons button at the bottom left hand corner of the character selection screen
Well the annoying little map in battlegroups can be gotten rid of by pressing shift+m :P
Rest are just mods
Bags = allinoneinventory or any other similar bag mods
If you dont like something, just go through your list of addons on your character selection screen and disable the crap you dont want :) or just delete them individually from your addons folder.
