I'd like to use two 92mm Noctua fans to provide airflow to the top and bottom of a built in wardrobe.
I have a socket so I thought I could use the Noctua NV-PS1 for mains to 12v, and then the Noctua NA-FC1 as a fan controller to control the speed of both fans.
This issue I have is the fans are going to be situated about 2.5 meters away from each other and I can't find any 4 pin fan cables that length because it's quite a niche use case; obviously daisy chaining loads of fan cables adds lots of failure points.
Anyone got any ideas as to how I connect both fans to the NA-FC1 quite far away from each other?
