Warm Boot Problems P5B Deluxe
20 Aug 2006
Finally getting 8x401 + to work on my E6600 ... but
even though Orthos stable 2 hours + ...
if you restart windows or press reset, or even power on pc - it will not post - just hangs there ...
but if you turn off power and back on again at the back, then turn on pc - boots prefectly .. and Orthos stable.
any ideas please ?
thanks, Mark.
Put it to 400FSB.
Then use clockgen using CY25591 or around there to clock higher.
Gives you the lower quicker strap and still allows you to hit >430FSB :)
CR.
that sounds a bit complicated for me to be honest. but thanks for the suggestion.
Bizarely - I found out that if I did a "reset" from windows (ie using the windows reset function) - pc booted fine ...
but if I pressed reset - or turned the pc off - and turned it on "softly" - from the front of the case - it would not boot :(
in fact it was so bad the last time - that it took about 9 power cycles just to get back into the bios ! Too close a call for me ...
interestingly though ...
my Vanderpool option in "CPU options" has always been greyed out - now I can select it enabled or disabled - bizarre !
