Warning: Dual Boot and Vista System Backups. System Restore and Shadow Copies
Permabanned
3 Dec 2006
If you dual boot Vista and XP you should know that booting into XP will delete all you shadow copies, system restore points, and all complete PC backups (on Vista).
You have been warned.
The only workaround is to disable the drive that holds that data.
