Warning to anybody with a WMR Virtual reality headset
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
I noticed today and Microsoft have removed support for Windows Mixed Reality devices from Windows 11 24H2 onwards, this doesn't affect all headsets, but will affect some for sure.
Windows Mixed RealityWindows Mixed Reality is deprecated and will be removed in Windows 11, version 24H2. This deprecation includes the Mixed Reality Portal app, Windows Mixed Reality for SteamVR, and Steam VR Beta. Existing Windows Mixed Reality devices will continue to work with Steam through November 2026, if users remain on their current released version of Windows 11, version 23H2. After November 2026, Windows Mixed Reality will no longer receive security updates, nonsecurity updates, bug fixes, technical support, or online technical content updates.
This deprecation doesn't affect HoloLens. We remain committed to HoloLens and our enterprise customers.
Source = https://learn.microsoft.com/en-us/windows/whats-new/deprecated-features
It's bad how MS have in effect abandoned support for many VR headset owners, I owned a Reverb G2 for a while in 2022 iirc, very good vr hmd imo I bet there are many people still using them and other hmd's who are going to be affected by this.
Sign this petition. Might help who knows, worth a shot. Failing that I have pretty good faith in the modding community these days and some legend will probably make a tweak as mentioned above.
This will never happen. Yes there is a linux project called Monado and that kind of works with the Reverb G2 but it needs a lot of tricking around with to get working.
And It will be like most other Linux VR projects, it will never come to windows.
I hope I am wrong.
Boooo, Hope you are wrong.
Have to say much as I still love my G2 I got a PSVR2 for PC recently and because of this and aside from the obvious OLED vs LCD differences, I now find the G2 incredibly dim compared to the PSVR2.
I believe the G2 is only 150nits panel brightness whereas the PSVR2 is roughly double that I think. Makes such a massive difference coupled with OLED black levels and colour superiority. I only use the G2 for MSFS now, as the clarity is still way better which is needed in flight sims.
To indulge my VR home room/environment obsession I picked up a Lenovo explorer for cheaps off ebay. Although not stated in the listing, the condition is 'as new' and even came with fresh batteries. I'll set it up on a fresh install of windows and dump a clone of the drive on the interwebs, before M$ kills it.
I posted about this issue in the Reverb G2 thread. Around 10 WMR headset models, including the Reverb G2 (which is still a very capable headset), are bricked by this update from Microsoft.
Windows 10 is still OK for now, you can update to 24H2 and WMR will still work because it is a separate app. The WMR app for Windows 10 will remain in the Microsoft Store until 2026.
But in Windows 11, WMR is embedded into the O/S and that is ripped out in 24H2. For now, there is no solution, other than remain on 23H2. With registry settings you can block 24H2 but still obtain security updates. If you would rather not edit the registry you can use the freeware utility InControl from GRC to do this for you.
What is really bizarre is Microsoft have announced Windows apps running on Quest for spatial/volumetric computing. So they still want to play in the VR space, but at the same time kill off their own platform. :confused:
There are projects such as Envision/Monado which aim to fully support WMR on Linux, but they are still classified as highly experimental.
An install of Windows 10 or Windows 11 23H2 is still the best option if you want to play a commercial tiitle.
Hmmm, I wonder where all the all the current addons (home accessories) are downloaded to. Can they be stored on the PC when it's offline. If the server is shut down, could these be saved and put in the 'accessories download cache' folder and so you'd still be able to mod the home environs in the future?
The Oasis driver is a native SteamVR driver (Direct Mode), it does not need the Mixed Reality Portal. It supports full 6DoF functionality, along with motion controllers. (Also, btw, it is NOT Monado and doesn't use any of their code).Restricted to Nvidia GPUs due to the way Valve/SteamVR interfaces to the GPU drivers.
I knew some geeky ****** genius would rescue the G2. **Massive** respect to the guy responsible, though I have a Crystal Super on order so may be redundant anyway....
Great news, now I don't have to try and sell my Reverb G2 :)
