Warranty on the prebuilt systems.
I'd guess that it will be a 1 year RTB but send OcUK a webnote to clarify this point. If it is faulty then you'd need to inform them and sort out the return between the two of you. :)
Nivforever said:
Just about to order this one:
http://www.overclockers.co.uk/showproduct.php?prodid=FS-041-OK
And realised there is no info about warranty. Has anyone ordered one of these before? and what should i do if it's faulty?
Also, im getting the Dell Ultrasharp 2407WFP 24" to go with it. What kind of experience should I expect from the new dx10 games?
Thanks
Not to change anything but have you considered building your own system? If you build your own system you could get GTX which will be perfect for a 24inch Screen.
As for the Monitor take a look at this one:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-047-LG&groupid=17&catid=510&subcat=
Reviews are brilliant.
Sorry didnt want to interfere or anything its just you can do much better for your money to be honest:
LG L245WP 24" Widescreen HDMI LCD Monitor - Black
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz (1066FSB)
Noctua NH-U12F (Socket LGA775/754/939/940/AM2) Heatsink
Arctic Silver 5 Thermal Compound (3.5g)
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard
CellShock 2GB (2 x 1GB) DDR2 PC2-6400C4 800MHz Dual Channel Kit
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
Creative X-Fi Xtreme Gamer Fatal1ty Professional 7.1 Soundcard - Retail
Western Digital Caviar SE16 500GB 5000AAKS SATA-II 16MB Cache - OEM
Samsung SH-183LBEBN 18x18 DVD±RW Dual Layer Serial ATA Lightscribe ReWriter (Black) - OEM
Sony Floppy Drive - Black
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU
Lian-Li PC-7 PLUS Aluminium Midi-Tower Case - Black
With Monitor:
Total : £1,676.50
Without Monitor:
Total : £1,163.04
truebluecfc said:
Dont buy it, they dont even put in the parts they say they do ...
Are you serious?
Also I dont want to build a system myself because I haven't built one before and dont have the experience and just really don't want the hassle
its easy.. i was 15 when i first built mine. and am still using it now.. and am sure a load of lads will give you a hand if you get stuck also take your time building it :)
Find it pointless to be paying nearly £1200 for a system that can be built a damn sight cheaper.
Its still reliant upon on-board sound ffs...!!
if you dont wanna build it yourself you could still buy the parts then get a local computer shop to build it for you for a fee. also building a pc aint hard as it looks. i did my first one when i was 15 too. there are plenty of guides on the internet that have pictures that will guide you step by step
Er a local computer store wouldn't build a pc for free with components you bought somewhere else. If you bought th
e componenets there then yes but if not no.
However if you have a friend that has done it before ask them and help out as they build it. If there is something your are unsure about then ask that way if something does go wrong you can have a go fixing it yourself.
