So my wife has already started complaining about her Picasso, the following problems have arisen:
1) Squeaking over bumps, in and out of gear, pulling off etc, presume this is possibly suspension related.
2) Economy mode sometimes comes on as soon as the key is in the ignition, sometimes it takes 5 minutes, sometimes 15, possible battery and or charging problem?
3) Getting a turbo charger type whine when accelerating (there's no turbo)
4) Passenger window rattles around like it's not secured properly when open and driving at any speed.
5) Breaks squeal, nothing major but still annoying.
As it's a "Citroen Approved Used Car" and it states
I assuming she can just book the car in and have the lot fixed under warranty with no argy bargy?
the Citroën Select Approved Used warranty package is equivalent to new car* cover and is supplied to you by your Citroën Select Approved Used retailer.
*Does not cover paintwork or front windscreens.
