12 Mar 2011 at 18:27 #1 skinneyb skinneyb Associate Joined 17 Feb 2011 Posts 185 hi can so one tell me the best warter cool monatering sofwere is that will also shut down pc if temps get to hight thanks
12 Mar 2011 at 18:44 #2 1kiwi 1kiwi Soldato Joined 25 Oct 2007 Posts 6,911 Location Los Angeles Your mobo will shut it self down if the CPU gets too hot. To regulate fans/pump speed you can use Big NG.
12 Mar 2011 at 21:32 #3 cjgardens cjgardens Soldato Joined 26 Aug 2010 Posts 3,395 As mentioned your mobo will do that. Will be a setting somewhere. Set it to 75 80c dont think there is software to monitor the water. If that's what you mean. You can get hardware. Ive seen a thermaltake one
12 Mar 2011 at 21:49 #4 1kiwi 1kiwi Soldato Joined 25 Oct 2007 Posts 6,911 Location Los Angeles This is what I was talking about. It comes with hardware and software (obviously).
