Was aiming for £500 (oops)
This would out perform the i3's with anything graphics intensive. You get a 2TB Hdd, a 128Gb SSD, a CPU thats overclockable and just generally great performance.
You could try your hand at gaming with this as it will play games such as Battlefield 3 @ 1920x1080 with Medium preset with an average of 40fps if you set the iGPU to auto boost in bios (Overclocks if within thermal threshold).
It has a large SSD for Os and loads of apps. Then 2Tb for all your media. 8Gb of highly clocked Ram and also a rather snazzy but cheap case!
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor (AD580KWOHJBOX) £99.95
1 x Plextor M5S 128GB Solid State Drive - (PX-128M5S) £82.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £71.99
1 x Gigabyte F2A85XM-D3H AMD A85X Chipset (Socket FM2) DDR3 micro ATX Motherboard £61.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD38G2133HC11DC01) £49.99
1 x Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046-UK) £40.99
1 x NZXT Source 210 Elite Midi Tower Case - White £39.98
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £12
Total : £473.99 (includes shipping : £11.75).
YOUR BASKET
thats great thanks like the mix of components
not digging the case though
thanks for the swift and helpful reply's guys
lots of options to look at there i will have to go through oc's website again and mix it up a bit want to get it right only want to do it once for quite a while,whilst leaving it open to add to it a later date if needed
dare i ask the difference between Amd & Intel is one better than the other at certain tasks
or just a different make of cpu thats it
