Hi there - I've ordered a Bosch washer dryer (WDU8H549GB) on the assumption that it has a particular feature, but the manual is confusing so I'm seeing if anyone on here can confirm.
From past dryers, the very most useful features was using the drying function as an iron for dry clothes - a quick 10 mins of heat to get rid of the worst creases. Made the world of difference.
From reading this manual there is a dry only setting where you can seemingly set a timer (called 'mytime'), but the machine drys to a certain levels of dryness. Which has made me realise, it's just going to detect the dry clothes are dry and then stop... which would be maddening.
Does anyone know if the 'mytime' setting just allows you to dry for a certain time, regardless of the actual dryness of the clothes? Thanks.
Sorry for the boring thread
Edit - oh, there is an 'iron assist' function that looks promising. Anyone use that...? God this thread is bleak
Mine dosn't even reverse tumble, Even very cheap tumble dryers normally do this
