Hi, today my washing machine stopped rotating, the cycles would go through but no motor, you could hear the relay click on and off, but nothing.
Opened it up, the belt is ok, everything looks in place (although quite rusty for some reason!)
Anyway, long and short of it is that by ******* about spinning the drum/motor myself and turning it off at the mains for ages, it seems to have started working again! (Hurrah!
I note however that the motor has blue flashes coming out of it when it engages, now the thing is i havent ever seen a washing machine motor go without the casing on, so i dont know if this is buggered or whether it is normal. Basically when the motor is running blue light is emitted into the casing (not visible from the front or with casing on)
Is this safe or will my house burn down in a fiery mess?
)I note however that the motor has blue flashes coming out of it when it engages, now the thing is i havent ever seen a washing machine motor go without the casing on, so i dont know if this is buggered or whether it is normal. Basically when the motor is running blue light is emitted into the casing (not visible from the front or with casing on)
I want to know how long i have before 1CM brushes will finally die? I'm assuming soon if its stopped once already.
