We got a Haus WM-1050W White Washing Machine the other day. It's a connected to the cold tap. The Washing Machine is set to 40c and the water wont get hot at all.
We phone up the maker of it and they just say "Try it on 60c, If that don't work connect it to the hot tap."
Well, if we was to connect it to the hot tap it would just you all the hot water witch we don't want. Any one got any idea what is wrong?
Here are the specs:
* Energy rating A.
* Washing performance B.
* Spinning performance C.
* Maximum spin speed 1000rpm.
* Maximum washing capacity 5kg.
* Variable washing temperature.
* Cold water fill.
* Size (H)85, (W)59.5, (D)53.5cm.
* 15 programmes in total, including:
* 145 minute 30 degree C cotton wash.
* 34 minute quick wash.
* Woollens.
* Rinse hold.
* Prewash.
* Silk wash.
* Economic wash.
Technical specifications:
* Energy consumption: 0.95kWh/cycle.
* Water consumption: 49 litres/cycle.
* Estimated annual energy consumption: 190kWh/year.
* Estimated annual water consumption: 9800 litres/year.
Thanks for any help.
Here are the specs:
* Energy rating A.
* Cold water fill.
* Woollens.
* Rinse hold.
* Prewash.
* Silk wash.
* Economic wash.
