Washing Machine Help
27 Mar 2013
Nottingham
So my washing machine appears to have given up the ghost, the door is locking the cycle is starting, it fills up perfectly fine then makes the noise as if its spinning but the drum is motionless. I can turn the drum by hand just fine. It counted down fine and drained at the end of the cycle fine but obviously it didnt spin so the clothes were still very wet. I noticed lots of white flecks in on everything after, I pulled the filter and it was pretty much spotless. Any ideas? Im guessing from the noise I am hearing the motor is fine but maybe some sort of belt is the issue.
The machine is an Indesit IWD 71250s. It was from a family friend last year as we moved unfurnished and they were moving themselves so no longer needed it so its no hard feelings if its time to upgrade and get a new but if its a simple fix may as well try and get some life back into it.
If fixing turns out to be pointless what brands should I be getting/should I be avoiding?
