Hi all,
I've got a Hotpoint Aquarius WF250 1500 spin washing machine and the concrete weights at the top and the bottom keep coming slightly loose so when it is on the final spin it makes a horrible knocking sound.
We called out a hotpoint engineer and he came out and took the machine apart and did up the bolts for a stupidly large fee. Luckily I paid close attention to how he got the machine apart, taking the seal out around the door etc, etc.
The problem returned within a few weeks and I tightened them up myself. I keep tightening them up and they keep coming lose again eventually. I'm absoltely terrified of over tightening them!!
This is the 2nd WF250 I've had this problem with, the first one ended in a horrible way when after about a 4th attempt at tightening these, I over tightened the bolts with the 13mm spanner and snapped the plastic where the bolts screw into the drum.
I used it for a bit but then it all went bad and the machine destroyed itself from the inside out! I REALLY can't afford to have this happen again.
I thought about getting a torque wrench to tighten the bolts up to the maximum they can be before disaster strikes. But I don't know how I would find out how much it can be tightened to safely?
Every time I have to tighten these things up I am literally crapping it incase I break it again. This was an expensive machine and we certainly can't afford a replacement.
Anyone know if this torque wrench idea is a good one? or how I can stop these things coming lose, without damaging anything?
At the moment we are just washing half loads as it makes the bolts stay tight longer.
Any advice would be much appreciated.
Would also love to know if there is anywhere to download a manual for this machine.
Cheers,
G
Cheers,
G
