Washing Machine Pump / Multimeter Help
28 Dec 2003
Aberwristwatch
I think the pump on our washing machine has gone, I've watched a few youtube videos and so have bought a multimeter to test it. Only thing is, I don't know how to use it.
Switch the multimeter to 500v~ then connect the red and black leads to the two spade terminals you've pulled off the pump motor and put the machine into drain/pump cycle and check if there's 220/240v being delivered when powered on.
If you've got power there then the motor is toast.
The multimeter didn't come with clips, only the probes. I presume it's safe to be holding these while taking a measurement?
spend a couple of quid in halfords and buy two (probably have to get more than you need) male amp tags, assuming you have a bedside lamp take off the plug and crimp connectors to live and neutral.
with washer disconnected from supply connect up the lamp to the two female connectors you took off the pump, wrap some insulation tape round connector.
put machine onto a drain program, if the lamp lights power is going to the pump, if not it could be pump or blockage (check waste spigot and if you can blow through discharge pipe)
ps if you put that multi meter to ohms (anticlockwise seventh one by looks of it) then connect to the pump you should be looking at 200-300 ohms for a good reading, although that still doesn't rule pump out.
They should be fine to hold then, but not sure I'd trust it to be honest. £9 multimeter just seems too cheap in my eyes - my lead set cost much more than that alone
On the 200 setting (6 o'clock) it's reading 192.8
On the drain cycle it hovers between 220/240 for about 5 seconds, goes down to 110 for about 5 seconds and back up again etc
If it's of any help the motor part (see picture in first post) has a sticker with the following on it.
220-240v
30W
50Hz
CL. 155
£20 for a generic one, £4 to send it back. I've tried swopping it out for a similar one from a spare machine we have in the shed, but it wouldn't fit.
