Evening All,
Fitting my O/H's new kitchen at the weekend and now need to source (or at least discuss) options for the washing machine waste, as we are a little short on space to get the fridge-freezer in fully.
The washing machine is in a twin cupboard with the fridge freezer, which is on the opposite side of the room to the mains feed and sink. So the rear of the cabinet has a little pipe work behind it. Namely a 40mm trap which takes up 6-7cm of depth.
Originally the waste pipe (which comes out the floor) was behind the washing machine stopping it fitting in fully. So I moved this (below floor level) to behind where the fridge is. Whilst this now means the washing machine fits perfectly, we are shy on depth for the fridge/freezer instead
But as it is the shallower of both appliances it is the better option.
Is a U-Bend really necessary for washing-machine and sink waste? Most appliance waste hoses require an inverted 'U' shape during installation so I'm wondering if this is good enough to stop any odours and we could simply mount a hose connector on to the waste pipe just above floor level and be done with it?
Thanks.
Thanks.
