watchdog violation
10 Apr 2015
Hungerford, UK, Earth
whats the best way to resolve a watchdog violation. Nearly everytime I boot my gaming pc (in sig) it crashes with a sad face and a watchdog violation, after the reboot its fine... but it will repeat the next time I turn it on
I would suggest going through the dump files to see what is causing the BSOD as it could be a driver causing it, but since it doesn't happen all the time it could be something else (or something that will require some further investigation or a full reinstall of the OS).
Might want to check the error code as well, should give you an idea what the cause is. A quick search on Google points it could be a driver for something needing reinstalling.
