Watching pc movies on tv help please...
11 Jun 2005
london
Basically what i'm trying to do is find the most efficient way to play downloaded content (eg 24 etc) on my tv. I had a couple of ideas but none of them seem to be perfect. My initial ideas were:
1. Copy the content onto dvd's using nero vision express and watching them through a dvd player. Didn't like that idea because I would need to keep loads of dvd's and it takes quite a while to author a dvd.
2. Get a media centre pc. That would cost too much seeing as i still want my desktop pc.
Any other ways this can be done?
Thanks
Well my graphics card has an s-video out, so I use that connected to a scart connector into the TV and voila! Sorted.
Doesn't do the sound though, but that's easy to sort out.
What do you mean get a media centre pc? it's no different to any other PC. Depending on your TV connections plug your PC into your TV add some playback software and hey presto it's a media centre PC.
Alternatively you can get a network player like the Snazio 1310/1350 which will playback content on your PC via wireless/ethernet to any display.
thanks for the help guys...would have connected the pc to the tv directly but they are quite a distance apart (approx 10m i'd say). I think i'l look up the network player...thanks again
Just go down to ****** or any other cable type shop and get an extended S-video cable in that case. It will work out cheaper than getting a network media player, or any other option really.
Works an absolute charm.
