Water additive?
4 Feb 2007
Nuneaton, UK
Is water additive really needed? Will it drop my temps at all? At the moment I'm just using plain distilled water.
If it does help which is the best one to go for?
Thanks
Ah, thought I read one that said it helped with heat transfer but at the time I did think it was a marketing gimmick, always best to ask though.
So I'll be fine with just plain distilled water?
You can drop temps with it in theory as there's some magical alcohol:water mix ratio that works better than plain water. But Irl there's really no point.
