Hello all,
Hopefully this is the best place to post this as I know that posting it in watercooling will attract more responses in favour of it....perhaps.
I'm in the process of speccing a new rig and I'm absolutely stumped on what to do with the cooling to extent that I'd better ask here.
To give you a bit of background that will help here...I currently have a custom loop consisting of an XSPC RX360 + 120, DDC Laing 10w (reaching end of life expectancy), Heatkiller block (soon to be useless due to socket change) and EK res.
Whilst I've only had one problem with watercooling in the past 5 years it was a significant one. I previously had 2 loops, one for the gpu and one for the cpu. One day the pump for my gpu loop died and wasn't detected until the gpu essentially boiled the static coolant in the loop until the pressure forced off a tube and it hosed my graphics card. I still continued with watercooling after this however it has always been a concern about something similar happening again.
As a result of this and the combo of having a small kid, clumsy not so small dog and another child on the way I need trouble free cooling that will be as fire and forget as possible. I plan on using it to cool a 5920k with a fairly conservative overclock of around 4ghz.
With all of this in mind could you please recommend the best course of action and possibly answer the following?
Has air cooling improved sufficiently to make it a viable option to cool a 5920k at 4ghz with a bit of headroom?
Would an AIO cooler be better?
Are AIO's like the Corsair h105/h110 reliable enough to not worry about?
I've heard people complain about the noise of AIO's...are they noiser than the pump (DDC-1t) that I'm coming from?
Considering I'll only be able to use my radiators and res in a new build would I be stupid not to just buy a new pump and block and have another custom loop?
The price differences of doing any of the 3 options aren't enough to put me off doing any. The choice is purely down to what would provide the best reliability - noise - performance ratio. Reliability is more important than outright performance this time around though.
Any suggestions or help would be most welcome. I seem to be swaying more towards a good air cooler like the Noctua nh-d15 or Cryorig R1 but worries of ram clearance on the x99 boards put me off slightly. An AIO would also be good however I don't know much about the recent ones and how reliable/noisy they are.
Thanks
Thanks
