Windle said:Should move to ScotlandWater rates come inclusive with Council Tax.
dirtydog said:Sounds like you need to use less water basically. In my experience you need to use a hell of a lot of water on a meter for it to cost more than the fixed rate would do.
the house is less than 10 years old, i think we would have figured if there was a leakWas said:errr...
I would check you dont have a leak or fix dripping taps,
turn off everything that uses water and check the meter isnt still turning...
Thats a silly amount of water
jamoor said:the house is less than 10 years old, i think we would have figured if there was a leak
i think we may just use loads......
Ouch! Watering your neighbours for free!Windle said:There could also be a problem with the meter, it's not uncommon and there could be other buildings being fed off your meter, again not uncommon![]()
