Im not sure if all water block braces/brackets use this as this is my first kit.
I stuck the foam onto the metal clamp that goes onto the back of the mobo then proceeded to peel off the side that would be onto the mobo, all the while thinking it will be ok i will only be using it on this mobo, what do you know had to RMA the board.
Just a question to see if anyone has done this too and what they used once they got the board back as all the foam is damaged n torn
