Water Block for 1070ti
3 Jan 2019
Howdy,
i am after some advice i would like a water block for my new graphics card but cant seem to find any thats say it will fit do the 1070 just fit the 1070ti?
the card i have is GIGABYTE GV-N107TGAMING-8GD NVIDIA GeForce GTX 1070Ti T Gaming any help on this would be amazing
From what I've been able to tell reading around, the 1070Ti reference PCB is the same as the 1070 reference PCB. No one has confirmed this for me though.
So 1070 blocks should fit your card assuming it uses a reference card design. Is it a blower style card, one big fan in the rear?
Hi and welcome to the forums. :)
According to EK's cooling configurator they don't do a block for it so it's not likely to be a reference pcb. I checked other 1070ti's using cooling configurator and they don't do blocks for any of Gigabytes 1070ti's and only reference cards such as the blower type cards from other manufacturers. I think your best bet would be one of those Chinese blocks but I just can't remember the brand now. Don't be put off by them being Chinese built as they are very nice blocks. I am sure someone will come along with the brand name.
I have now been looking at EVGA rtx 2070 08G-P4-1071 do you think ill be better buying that over the 1070ti and then picking up a block when they are released?
Bykski make one that will fit i think.
I can't link to competitors, however googling the brand Bykski and your card name should get you a few options.
That's the one I was trying to think of. They seem to do blocks for many cards that other manufacturers haven't catered for.
