Water block recommendation for xtreme x99 bundle
9 Sep 2011
Hello, just about to purchase the xtreme x99 bundle, but when i called overclockers earlier i forgot to ask for a recommendation on water block for the cpu. And would you recommend watercooling the board also.
I'm completely out my depth here and probably should be buying a pre made system but wheres the fun in that.
any input on water blocks would be great
Not quite 8Pack, but got some watercooling experience ;)
Which exactly bundle? Can you link it?
Most high-end motherboard are very well cooled on the VRMs. If you feel like you want to watercool it, then go for it. I haven't bothered myself, even though my CPU (Z170 XPower + i7 6700K) runs fine at 5.0GHz. Just don't forget it is hell lots of a hassle. And if I were to watercool my motherboard, I'd probably do a secondary loop for it.
That's a block I would get for X99 based CPU:
https://www.overclockers.co.uk/ek-water-blocks-ek-supremacy-evo-x99-full-nickel-wc-845-ek.html
Got similar myself, but for 115x socket.
I actually prefer just the CPU water cooling with the EK EVO block. The full cover blocks for me look great and work well but CPU temps are compromised.
