- 6 Nov 2005
- Oxford
Im getting very confused about wich blocks will fit my card. Could some one give me a list of possible blocks. I dont mind a small amount of moding it needed.
blasphemy!Rob43 said:Using the Swiftech MCW55 on my X1900XT.You just use the Nvidia fittings to get it on![]()
Jack Bauer said:also if I where to get the swifttech does it come with the fittings above?
Cheers for the replies btw
Goksly said:blasphemy!
Goksly said:Do you notice any shimmering or lower IQ since you used those fitting Rob?![]()
